84 MAF problem
Itzav6
i have an 84 ttype with the stock MAF I don't hear any turbo spool. Vehicle drives but stalls out when I take the MAF off the vehicle runs and idle fine. I have an 87 MAF and an 87 ECM but the ECM came with a street chip which my stock 84 doesn't have the proper injectors for. What can I do ?
If your maf piping is not sealed properly, it can cause unmetered air to enter, causing a lean condition. The maf could be bad. Or the injectors for the new ecm are greater than 10% of the stock size and may cause a lean condition due to the pulse-width of the larger injector. It's best to check for the first two to eliminate those possibilities and then install the correct injectors. Lean is bad.
