'84-'87 Buick Grand National Engine Parts
MGTech30
200 4-R ODrive cable.jpgA C Brace.jpgBalancer Pully.jpgCam Sensor.jpgCoil Pac.jpg1987 - Driver side header
1984-1985 - Boost Control Solenoid
1984-1987 - Fuel Injectors (2 sets)
1984-1987 - Fuel Injector Wire Harness
1984-1985 - Fuel Injector Rail with Retainers
1984-1987 - Fuel Pressure Regulator
1984-1985 - Mass Air Flow Sensor
1984-1987 - A/C Bracket
1984-1987 - 200-4R Overdrive Solenoid
1984-1987 - Cam Sensor
1984-1985 - Coil Pack
1984-1987 - Crank Sensor
1984-1987 - Camshaft (2 available)
1984-1987 - Flexplate/Flywheel
1984-1985 - Clutch Fan with NEW Clutch
1984-1985 - Up-Pipe
1987 - Rear Springs (2 sets)
1984-1985 - Induction/Air Intake Tube
1984-1985 - Intake Manifold
1984-1985 - Throttle Body
1984-1987 - Timing Cover
1984-1987 - NEW Timing Set (Double Roller)
1984-1985 - Water Lines
1984-1985 - Throttle Body Water Lines
1984-1987 - Water Pump Pully
1984-1985 - Power Steering Pump
1984-1987 - Push Rods
1984-1987 - Oil Slinger
1984-1985 - Fuel Filter Line
1984-1987 - Crankshaft Pully
1984-1987 - Autolite Platinum Spark Plugs
How much for the 84/85 coilpack shipped to 92805 ? Is it just the coilpack or is the module included as well? What does it ohm out to from post to post ? Thanx
$185. I don't know the ohms but I know it works because it came off a running car. Its a complete coil pack also.
