1 Baro
2 TPS
3 Coolant
4 AIR solenoid
5 Trouble Code Test Terminal
6 EFE
7 Coolant return
8 ISC
9 O2 hi
10 Dist ref Hi
11 Ignition Module Bypass
12 EST
13 Dist Ref Low
14 O2 Low
15 -
16 VSS
17 3rd gear
18 M/C Solenoid
19 -
20 MAP
21 5V Reference
22 Sensor return
A Ground
B Air Swicth Solenoid
C Ign 1 Power
D
E EGR Bleed
F ISC motor extend
G Check Engine
H Park/Neutral
J A/C on
K -
M ISC motor retract
N 4th Gear
P TCC
R Long Tem Memory
S -
T EGR
U Ground
