I though I posted back on this. Guess not.
Timing is not the issue with your motor.
You have plenty of injector. Almost too much but it will work just fine.
I suggest you have a look at your fuel pump make sure it is working correctly or it may be that the pump is not big enough.
If you know that is good, start adding more fuel to the top of the map.
If you are knocking a lot be careful, that means you are detonating for lack of fuel.
Do you have a way to check A/F ratio or EGTs? That would be a big help.
