5 apples...
Winsett
I just wanted to give a quick update as we also ran a new best.
5.12@127 (in the 1/8th) at 3060lbs - some of you guys may note that this is not the best 1/8th mile ET for the car... you are right - it has been 5.10... but this last performance was with no high gear, bouncing off the rev limiter in 3rd thus the reason for such a low mph...
so where is the new best at? 1.20 - 60' =) With high gear it should run aight...
Winsett
www.meankidsracing.com
1/8th mile MPH
I actually had to look at the log book to see.
On the 5.10 pass it was 144 but remember it blew the up-pipe hose off.
In BG this year when the car went 8.3@168 the car went 149 to 660' but I had to lift because I was loosing the hood that was really the only good pass at BG and even that one the 60 was really bad 1.32
If I can get it back together by this weekend it should post a number up in Oklahoma...
Winsett
I was going to guess 145 based on our emails.
Good luck and I am working on passing the word around for you.
