I am getting a transmission, converter, dipstick and tube, wiring harness and computer, trans yoke from a 94 diesel truck (and anything else I want from it).
I am installing in a non computer controlled vehicle (81 monte).
I figure I will need a TPS, aftermarket trans tail stock to use my mechanical speedo.
what software and wiring will I need to change shift point and line pressures or do i need to burn a chip to change this stuff?
Anything else i should know?
What flexplate do i need to bolt the converter to?
I know I need to grind part of the case and pound the floor abit for clearance. I figure I will also cut off the ears so i dont need to remove my long tube headers for R&R'ing it.
Thanx
Thanx
