4L80E set up for turbo buick
maybe 2-3 passes since re-done
re valved valve body with all new selenoids
new alto red clutches, new seals and new Kevlar band
36 element sprag
plenty of upgraded hard parts
plenty of modifivations
dual speed sensors
rossler electric trans brake only one that works with a full automatic valve body
http://www.rosslertrans.com/4l80e Pro-Tree trans brake.htm
pro-torque 3500 rpm lock up torque converter spec'd for turbo v6
http://www.protorque.com/torque-converters-main.html
B&M deep cast aluminum transmission pan
http://bmracing.com/?wpsc-product=cast-aluminum-deep-pans-gm-4l80e-adds-3-qt
fabricate stock crossmember for 4l80e
GM performance parts supermatic 4l80e controller and wiring harness NEW STYLE
This is very advanced software. you can control any perimeter with your laptop. WOT, line press., shift vs speed, shift vs tps, all downshifts, converter lockup, and anything in between
http://www.gmperformancemotor.com/parts/19212657.html
ready to bolt in. no modifications needed to fit in the transmission tunnel
this transmission has been good to me. after having to re-build my fully roller fully built 200r4 like 10 times I decided to buy this setup. transmission has held up well at about 950 flywheel hp from my stage 2 engine.
I am selling this as Im building a 69 Camaro turbo lsx with a th400
We purchased a turbo buick from Kenny Duttweiler that had this transmission in it.
$3250 for the whole package plus shipping
36 element sprag
dual speed sensors
