Mark,
I read that thread and others that I found in the search on the Art Carr deep pans. I was wondering if anyone had problems or heard of problems assoicated with using the 4L60 and 700 filters.
I was told that there had been some pick up and flow problems with the 700 filters when used in the 200. Does the design of the filters change the flow and volume to the pump?
I would like to use the filters that set lower in the pan if they don't cause problems. On the other hand if I can use a stock 200 filter, crimp the metal on the filter and overfill the trans. 3/4 of a quart, I will go with that.?? I want to do whats best for the trans.
