DJackson1357
- Mar 15, 2010
A few years back the engine in my dad's 87 GN wiped a lobe and we're just now getting back to putting it back together. Due to some other issues, the block we had in there (85 20 bolt block actually) is junk. To replace it I have either a 484 4.1 block or a N/A 109 block. Both are standard bore and the 4.1 does NOT have any cracks on the deck surface. The rest of the combo will be:
- Champion Ported Irons
- 206 Roller
- TE-44
- Dutt Neck Intercooler
- PTC 2800 Stall Converter
- Meth Injection
Even though it's a bit overkill, either engine will receive a girdle, head studs and the rods already have ARP bolts. Boost will be limited to less than 20 psi.
For this application I'm really leaning towards the 4.1 for the additional torque and quicker spool. I know the 109 will be stronger, but I don't believe I'm really going to be stressing the 4.1. In searching through the archives it looks like a few people have had issues with cracking the cylinder walls (and some with cracked lifter valleys I think). Can anyone chime in on this? I've also been able to find people running 120+ traps with 484 blocks and cracked decks.
Any thoughts?
- 206 Roller
- TE-44
- Meth Injection
Any thoughts?
