G G-Force Member Joined May 24, 2001 Jan 27, 2011 #1 I Have here 4 front used gta wheels. They were on my car briefly and heald air perfectly with no flaws. $529 Shipped to lower 48 only. Attachments gta1.jpg 88.4 KB · Views: 913 gta2.jpg 86.5 KB · Views: 907 gta3.jpg 80.1 KB · Views: 906
S streetwavesauto Member Joined May 25, 2004 Feb 4, 2011 #5 G-Force - Would you consider splitting up the set? How much without shipping - I am up in Austin and can come get them next time I am in Houston.
4 41 willy New Member Joined Oct 18, 2008 Feb 6, 2011 #8 Do you still have them? Do you have center caps?
R ROYAL_6 Member Joined Jan 29, 2007 Feb 6, 2011 #10 Would you maybe trade for some T wheels? Maybe partial trade for something else?
G G-Force Member Joined May 24, 2001 Feb 6, 2011 #11 Sorry guys, no trade. I need the $$$ to fund some items for my T.
R ROYAL_6 Member Joined Jan 29, 2007 Feb 6, 2011 #12 Sounds good.. I have a few parts also I can do partial trade plus money if you change your mind. Good luck with the sale :biggrin:
R rw87tt Member Joined Oct 21, 2006 Feb 13, 2011 #14 GTA wheels What are the specs on the wheels? Is it a 16 x 8'' rim? What is the back spacing? Was there a differance between the front and back rims?
S slick6732 Member Joined Apr 13, 2010 Feb 13, 2011 #15 I have four fronts on my 87 T Type with no problems and no spacers if that helps!!
S Squid4life Well-Known Member Joined Jul 5, 2004 Feb 13, 2011 #16 rw87tt said: What are the specs on the wheels? Is it a 16 x 8'' rim? What is the back spacing? Was there a differance between the front and back rims? Click to expand... Look in the brakes/wheels section of this board. All the info you ever wanted to know about the GTA wheels. Rears and fronts are different, 4 fronts is what you want unless you want to run a spacer. 16x8 is correct. The GTA’s are marked “front” and “rear”. Front offset: Front backspacing: 4.75” Rear offset Rear backspacing: 5.25” This is a hell of a deal on 4 fronts!
