36mm sway bar,front brake upgrade
LSJM1
36mm hollow front sway bar cleaned and painted black satin,bar only $70 plus shipping
complete front brake setup 2 -11" rotors turned,spindles,hubs,dust shields,dual piston calipers with mounting brackets,hoses,bolts $220 shipped
I'd like to know what the front sway is from as well...if that's an f-body bar...I want it...or heck if it would fit with my FMIC I want it(in other words same type bends as stock). The only deal breaker may be shipping, if it isn't sold check to 72032 (commercial address).
The sway bar is from a 91 trans am it's bent like the stock one except for the v shape in the middle should fit with the front mount shipping would be $20 to 72032
I'm not up to speed on rear disk swaps if you can use the setup from a blazer I could get it for you
All the front brake parts are from a 2wd blazer the 4wd hubs spindles are not the same they will not work it's hard to find the 2wd parts most blazers are 4wd
