36mm front sway bar-12" brake parts
LSJM1
1 36mm hollow front sway bar -just the bar exellent shape no rust painted black satin $65 plus ship
almost complete 12" front brake setup consist of:
left and right blazer 2wd spindles
pair of hubs with good bearings
pair of stock 12" LS1 f-body rotors well within specs for turning
left and right LS1 calipers with mounting brackets,hardware,lines,and good pads
only thing needed to complete is caliper to spindle mounting brackets {fly-n-bye or ?}
$250 shipped
the pic of the brakes are all blazer parts the ls1 calipers and rotrs are a little different the LS1 caliper are aluminum dual piston bigger than the blazers
I could throw in a pair of g-body frame brackets and the stock rubber 36mm bushings I will get back to you on the shipping
the spindles are not in this pic they are still bolted to the blazer parts
I have the complete blazer setup for $225 shipped
I only have 1 set of spindles and hubs which would be used for either the 11" or 12" setup
sway bar sold!
LS1 calipers and rotors don't work with blazer spindles!
I want to sell the LS1 calipers and rotors for use with a modified stock spindle
$140 shipped for the calipers and rotors
I have a whole blazer 11" brake setup nothing else needed $225
