G Gbodyolds New Member Joined Nov 5, 2002 Sep 27, 2003 #1 when using the camaro 36mm sway bar do you use the camaro end links or the G-Body end links ?
captrob Slow GN Fizz! Joined May 30, 2001 Sep 27, 2003 #2 G-body ones. Or buy new poly ones. Just make sure they are the same length. HTH, CaptRob
G Greasemonkey New Member Joined Nov 12, 2001 Sep 27, 2003 #3 I reused the stock endlinks. I then later replaced them with poly, which did seem to help out a bit.
