ETicket,
Here is the list of items, I remember your post on Cody's thread about how nice of a car it is.. here is the spec sheet JIC. On the same note I will add that Cody has mentioned that the car does have " don't quote me on this " a 2 stage boost controller, he mentioned that downpipe is ok.. but that he has noticed the boost sneak up and well he thinks and I agree that I should consider an externally wastegated DP. On your post you hit the nail right on the head.. It does seem to sneak up and therefore the question? I am having a hard time getting a very nice used one.. they are pricey, I saw one here not too long ago but it's a 3" DP with Ext WG and Dump pipe.. just don't know whether or not to go for it.. I am afraid of losing performance if you know what I mean..
Performance:
234ci
109 block
.30 over Diamond Pistons
RJC Girdle
K-1 H-Beam Rods(floating)
Cat Crank(stock stroke)
Center Billet Caps
King Bearings
Hi-Volume oil pump
RJC Crank Scraper
JW(the wheel) flexplate
BHJ(internal) balancer
Port Matched Stock Intake
218/218 Hyd Roller Cam From DLS
918 Beehive Valve Springs
Comp 853 Lifters
Chrome-Moly Push Rods
Champion Ported GN1 Alum heads(porting done by Nick Micale)
70mm Throttle Body and Matching PTE Plenum
F.A.S.T XFI with 83lb injectors(including laptop)--from Cal Hartline-he helped me tune it
Full RJC Alum Pulley Set
PTE Front Mount I/C(new design)
TA Stainless Headers
PTE 70GTQ Turbo(3 bolt)
HRparts poly motor mounts
RJC Zinc plated deep sump oil pan
Full Billet 200r4 w/ Transbrake
Pats Perf. 10.5 L/U 3800 Rated stall converter
Denny's Nitrous Ready Driveshaft(all 1350 series w/ chrome moly trans yoke)
Moser 30 Spline Axles
Detroit TrueTrak Posi
TA Rear Girdle
3.42 Gears
FULL HRparts Rear Suspension with ajustable sway bar and control arms
Competition Engeneering Front and Rear ajustable shocks
S&W 8Pt Roll Bar
Aeromotive A1000 Fuel Pump
Alum 15 Gal Fuel Cell in trunk with sender(gas gauge works)
Fiberglass Front and Rear bumpers/bumper fillers just went on
Alum Bumper brackets
Has Dual Electric fans
3.5in Internal Gate Downpipe w/test pipe
3.5in Electric Cutout
B&M Quicksilver Shifter
ATR Dual Stainless 2.5 Exhaust(with Stainless Dynomax Mufflers)
Autometer Phantom pillar (0-35) boost gauge and (3-3/4) Tach
Kirkey racing seat on drivers side-grey color to match interior
RJC 5pt harness for both front seats
