Hi Sleeper, your best bet would be to pick up something like a mity-vac or another hand powere vac/pressure pump and calibrate the setup on your car.
The process is pretty simple. Take the lines from your vacuum/boost gauge, the 3bar sensor, and the mity-vac and "T" them together. Turn your key to the on position, start Direct Scan and draw a vacuum on the lines. Write down what DS reports as MAT for each inch of vacuum.
Then do the same as you slowly pressurize the lines incrementally up to what ever max boost level you're interested in.
You can get as detailed as you want by selecting what scale to take measurements. i.e. you may be interested in 1/4 inches of vacuum or 1/4 psi of boost resolution or you may want 2psi steps. Either way it's your choice and you know that the MAT temp reported by Direct Scan is an exact match for the boost gauge actually installed in YOUR car as opposed to somebody elses readings on a car setup completely different from yours.
Charles Brooks
