The 30" may or may not hook better. For me, the 28" is a better tire to use because the suspension works better with the shorter tire. The 30" is very tall, which raises the rear of the car up in the air. To properly transfer the weight , the front needs alot of travel. To set a car up properly for a 30" tire requires an extreme frame notch, wheel tubs and lowering the car alot.
