24 years of GN Parts HOARDING + New Head liners , visors and Bumper fillers up date July 2013
Intercooled88s
Moderator
-All prices do not include shipping, unless stated.
- NEW GM Passenger side Outside Black Window Dew Sweep belt molding(outer seal that presses against the door glass) $90
- AC delete bracket with belt $35
-NEW ABS backed head liner For 85-87 GN Med gray with Astro Roof $210
-NEW PUI ABS backed head liner 85-87 Med gray (Grand National) for hard car $160
-NEW PUI ABS backed head liner 85-87 Med gray (Grand National) for t-top car $160
-New PUI ABS backed head liner Maroon for T-top car $160
-New PUI ABS backed head liner 84-87 Tan for hard top $160
-New Visors In 85-87 GN gray, Maroon, and tan $90 a set(these are new not recovered)
-New 85-87 GN Front PUI bucket seat covers(drivers and passengers seat, upper and lower) $300
-New ABS Rear fillers with minor damage(easily repaired) $100
-New ABS Rear Bumper fillers $200
-NOS black wheel well moldings(both front and drivers rear) $100 Each
-85-87 GN gray dash speaker cover, in really nice condition(no cracks looks close to new, but has a slight warp in the middle $150
-85-87 GN console $300
-85-87 Gray console $300
-84-85 Billet vac manifold(part on top of throttlebody) with prevision for vac brakes $30 shipping included in the US
-86-87 GN center caps $20 Each
-87 GN dash pad $140
-Driver quality 86-87 GN wheels $75 Each
-Power Master $300
-Mega shifter for Turbo 350 $75
- gray 442 bucket seats $250
-GM crate motor 350 block # 10066036 4bolt mains Edelbrock carb and intake, headers, comp cam 1.6 rockers etc. $900
-nice set of 85 Maroon bucket seats $300
-87 Grand National Engine 100% complete, runs great $2500
-New tranmission shifter cable(after market) $18
-Hot Air(84-85) conversion kit to Intercooled(86-87) $1800 Includes almost all the stock 87 parts needed to convert over to intercooled, E mail for parts list
-Turbo Riviera Turbo $200
-109 turbo block std bore $300
-Good std/std turbo crank $300
-86-87 Engine wire harness(no injector harness) $200
-86-87 Intake manifold(lower and dog house) thats been painted $160
-84-85 GN front air dam $50
-New after market cruise control shifter lever $30
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $200
-84-85 stock trubo, very little play $150
- 84 GN front and rear seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-Autometer Boost gauge with A pillar single pod $25
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $100
-86-87 Belt tensioner $100
-87 Intake manifold(lower intake and upper dog house, with metal waterlines) $200
-87 Engine harness with inj harness $230
-Turbo shield $40
-Rad hold down plate $30
-Front license plate bracket $20
-86-87 Air dams $75
-Doors $400 for set(1 pass and 1 drivers) they are manual windows and manual locks have just the start of surface rust on under side. Pick up only, I wont ship these.
-Vac brake set up $100+shipping(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $250
-locking T-tops $200 a set
-84-87 RegalT-type header panel(has hole for emblem) with good black paint $200
-84-87 Nice Header panel (Hole for emblem has been filled) $200
-GN driveshaft $75
-Stock 109 Turbo long block(120k) $1000
-87 GN 109 short block, .040 Cast pistons, .010.010 turbo crank, never run $800
-86 NA 3.8 Engine complete runs good has 109 block $350
-84 NA 3.8 Engine complete runs good 290 block $250
-84 turbo Regal block .030 over $150
-85 Turbo Regal Block .030 over $150
-109 turbo block .060 over $100
-Turbo crank(Std/Std but will need to be turned at most .010.010) $250
-Under drive crank pulley and alt pulley $40
-86-87 T-type wheels(set of 4) no center caps $300
-Nice set of GN tail lights with blackout trim $160
-84-86 GN Power seat track assembly $150
-Floor brackets for console $30
-Regal doors(They have very little surface rust on under side) $150 picked up only
-Floor pan for bucket seat car $150 picked up only
-Rear quarter $150 each picked up only
-Rear frame rails $100 each
-Front frame rails $100 each
-Control arms(Front lower)$60
-Control arms(Front upper)$30
-Motor mounts(metal, frame mounts) $35
-Turbo crank(.010.010) in nice condition $200
-Turbo crank(StdStd but will need to be turned at most .010.010) $250
-NEW Felpro gaskets(2 head gaskets 8723pt-1, 2 cork valve cover gaskets,2 Exhaust manifold gaskets) $35
-84-85 Flex cooling fan $10
-85 Power steering pump(For car with power master) $30
- trans cooler $20
-B body spindles $50 for pair
-85 Maroon bucket seats $200 good condition
-85 Gray bucket seats $250 good condition
-Crank window regulators $50 for both doors
-Dash vents(with nice chrome) $20 each
-Nice Gray card board and cloth inserts(under quarter windows) From 85 T-type $30 for both
-Gray dash pad with a small hole drilled at the lower right of the drivers seat(Its not even noticable) $75
-Visors good for cores(non mirror) $20 a set
-Chrome marker light $35 each
-Both front head light bezels(need to be painted) $70 for both
-Rear center filler(The part that the rear license plate bracket attaches to) $30
-Pass remote mirror bracket(Just the bracket that attaches to the dash) $15
-NOS black plastic seat track cover for rear right side(GM part # 20023766) $20
-Frame in good condition $200
-heater box shield $15
-84-85 Shield to cover heat hoses $15
-bumperette rubber strips in good condition(used GM not after market) $20 each
-Stock factory lighter $8
-Stock Battery hold down $10
-Connecting Front Brace $25
-Front frame braces(underside) $25
-Plastic Brackets to mount front air dam $30 for 2(For both sides)
-Good hood shocks $10
-Stock turbo inlet bell $20
-86-87 engine hoist bracket(on intake) $20
-87 gray cloth Limited front and rear seats $200
-87 gray column (shift on column) $100
-87 Split bench seat power seat track assembly $100
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chromegray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $50 each
-Chrome(Regal) wheel well trim moldings $45 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $150
-84 GN steering column with tiltcruise $150
-Maroon steering column with tiltcruise $150
-87 GN grey column with tiltcruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $75
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-86-87 T-type wheels $100 each
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel senderfuel hanger(analog gauge) $60
-BQ tranny $250
-Rebuilt BQ tranny $400
-D-5 convert $75
-87 chrome grill painted black(looks good) $100
ENGINE PARTS:
AC compressor(84-85) $40
AC lines(84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $300
Cam position sensor just the lower part(no cap) $35
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $50
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $40
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $45
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$20
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers(set of 2) (84-85) $30
Valve covers(set of 2) (86-87) $50
Vapor cannister $10
Wire harness(84-85 engine wire harness) $150
INTERIOR:
I have every color interior part including green.
Arm Rests( grey, red, Maroon or blue arm rests) $20 for 2
Arm rest(Light sage green arm rests(these are the rare light green color)) $30 for both
Concert sound speaker covers(84 GN) $50
Console shifter plate(Plate on console that goes around the shifter)$25
Dash pad no cracks(grey or Maroon) $140
Digital dash gauge cluster $200
Door panels(85-87 GN lower door panels) $60
Door panels(85-87 T-type grey lower door panels) $40
Door panels(85-87 T-type Maroon lower door panels) $40
Door panels(85-87 T-type Blue lower door panels) $40
Gauge cluster(Analog) $100
Gauge cluster(Digital) $200
Radio(Stock GN radio with cass, no EQ) $40
Sail panels(Grey interior panels around the quarter windows) for T-top car $40 for both
Sail panels(Grey interior panels around the quarter windows) for Hardtop car $40 for both
Seats(87 GN Front bucket seats need recovering) $200
Shifter $35(84-87 GN, needs T handle)
Steering wheel(good to have recovered) $40
Steering wheel(Tri shield GN horn center $40 no ring)
Steering wheel(T-type horn center $30 no ring)
Steering wheel(T horn center $30 no ring)
Surround(Gauge surround) $30
Surround(radio surround) $20
Third brake light(Grey, red, Maroon, or blue Third brake light)$20 Each
T-TOP trim around the t-tops on the inside of the car in, Maroon, grey and blue $25 for each
piece
Body Parts:
Blackout trim for front windshield $30 each piece or $75 for all 3
Blackout trim for rear window $30 each piece or $50 for all 3
Blackout trim around the door windows $30 each piece
Blackout Drip rails(hard top) $50 for both
Blackout trim, T-top boot shaped trim that the T-tops lay on $60 for both
Bumper(GN Rear black bumper) $100
Bumper reinforcement(Alum. Front bumper reinforcement)$120
Bumper reinforcement(Alum. rear bumper reinforcement) $70
Front bumper shocks $25 for both
Rear bumper shocks $25 for both
Fenders(84-87 GN fenders(GM)) $100 each
Grill 87 GN Grill $200
Grill 86 T-type grill $50
Grill emblem(87 , says "Buick") $15
Hood(GN hood) $150-$250 (pick up only)
Hood Scoop(GN Hood scoop, cut from a metal GN hood) $50
Lock set(all 3 locks with key) $30
Mirror(Drivers mirror) $20
Mirror(Passenger Mirror,non remote)$20
Mirror(Passenger Mirror, Remote) $65
Quarter windows with blackout trim $150 for both sides
Wheel well(Drivers Turbo plastic wheel well) $100 each
Wheel well(Passenger Turbo plastic wheel well)
Any other blackout piece e mail me I have them all
Misc:
Antenna base nut and spacer for Power antenna with black trim $10
Control arms(Front lower)$50
Gas Tank(Turbo gas tank) $40 WON'T ship pick up only
Heater box(Complete heater box, For AC car) $120
Heater box shield $15
PowerMaster to firewall adaptor(bracket) $30
power trunk mechinism $20
Steering box(87 GN Power steering ) $35
Sway Bars(GN sway bars) $25 each
Transmission cross member $40
84/85 Tranny dip stick and tube $40
86/87 Tranny dip stick and tube $45
Transmission oil pan(Stock 200 4r tranny pan) $25
84-85 T-type wheels $40 each or 4 for $120
windshield wiper motor $40
-8.5 Rear end with new bushings, 4.10 gears, 35 spline axles and a spool $1000
- Art Carr 3500 stall 9 inch convert for Turbo 400(CPT converter from the real Art Carr) $200
-Bolt on bell housing for Turbo 400(12928 JE Performance- $150
Weldon pump $200
New NOS gauge $70
VDO boost gauge $25
009 injectors with low miles $125
87 Grill with a 2 inch cut to fit a small front mount intercooler $100
griffin radiator $100
I also have tons of New and used after market gauges, Pm me if your looking for any gauges, I may have it.
I'm interested in the gray 442 seats for my we4 so maybe they match? or another set you have? and gray nos visors....pic of seats? I'm in mass also.
Interested in the 86 t type grill 15025 please get back to me
Would you have a relay mounting pane? Need not be perfect, just serviceable. Cost to 68118. Thanks.
need left and right turn signal bezels for Turbo Regal. Black or chrome in the best condition you have. How much shipped to 72758? Please PM. Thanks.
