Hi ,I have many springs in my collection but i want to install this one.....length...2.100 WIDTH .515 WIRE THICKNESS .050 ,this is for a 2004r ,brf valve body with a ck shift kit, duel feed, boost valves, etc
The longer the spring is , the more pressure modulated tv oil will be as it exits the plunger ,This will raise torque signal to the boost valve as well as tv up oil to delay upshifts.This means by going to a longer spring without adjusting the cable the more preload will be on the tv valve and this will make shifts later and firmer at LOWER SPEEDS BUT NOT WOT.
