2004r questions/problems
Shifted hard from the get go, wouldn't shift into overdrive till about 85mph, then you can drop down to 70, went to put it in reverse the other day and it just rolls, does nothing when you give it gas, drove it home and would not shift out of 2nd automatic or manually, got it home and reverse started working for a second, added 1 quart of fluid and no difference tranny was supposably rebuilt when I bought it but has never worked right unless your full throttle then it shifts smooth, butnormal driving shifted hard until it all stopped! It's just a stock 84 gn with stock tranny, car has 123000 so I'm supposing tranny does to! Any ideas? Been told if you change filter then tranny usually craps out?
