you need to have the fuse interrupt or run the wires to the power wire at the ignition module , cut that wire and connect the two wires from the two step to the ends
there was a thread on it titled some thing like "ignition hot wire and 2 step" because if you have a casper ignition hot wire you cant use the fuse adapter as bob supplied
