Firechicken
- Jul 23, 2003
Hey guys, I just built my CZF trans using Ck's manual, but I have developed a 2-3 flair shift. When I first installed the trans last week, the 2-3 was ok except at WOT it hesitated for a split second. Now, after a week of driving, I did a WOT pass and it flaired pretty hard on the 2-3 shift. The engine bounced off the rev limiter before shifting into third.
The trans has been 'dual fed' and is using a transgo shift kit. The Transgo Performance Shift kit consists of:
The trans holds the power in 2nd without any issues, and it holds the power in 3rd, but it is getting from 2nd to 3rd which is causing the problem.
Any advice for me Chris?
- Heavy spring for 1-2 accumulator ( I have omitted the 1-2 acc completely and have blocked off the feed hole)
Heavier line bias spring
Accumulator valve spring
Spacer on low valve
.500 boost valve, int boost valve and PR spring
Enlarged holes in spacer plate at: 5(.110), 8(.110), 14(.086), 18(.110), 28(.110), 33(.055)
