Can't help with a schematic, but I can tell you the Neutral Safety, Reverse Light switch is mounted on the top of the trans where the manual shaft is located. It is adjustable by loosening 2 bolts. Make sure to check that it only starts in P or N, if you decide to adjust it trying to correct the back up lights.
