1985 olds cutlass supreme with a 1970 455 Oldsmobile big block engine has very little use light street use and only 6 track passes has forged pistons and all arp hardware. C cylinder heads and an edelbrock intake with a race demon 850 cfm carb complete msd pro billet distributer 6al box with 2 step th400 transmission with redline clutches and reverse manual valve body and a pro billet shifter chromemoly drive shaft. rear is an 8.5 out of a grand national with 3.90 gears full spool c clip elimintors and mosher axles big wheel cylinders and aluminum drums. Fuel system is all aero quip lines and fittings with Barry grant pump filter,holly regulator and rci fuel Cell .Car has all autometer gauges tach oil water volts and fuel with diaphram. Rci racing seats and the car has a 8 point cage welded to the frame.brakes calipers ballpoints bushings racing springs tierods manual steering box etc is all been replaced Car will run and drive but needs minor tlc paint is dull no rot but slight rust on some small easily repairable areas car is fast pulls tire off the ground off the foot brake ! Comes with 2 converters for transmission stock and 4500 which is a little to much for car I have thousands and thousands invested in this car no expenses spared on the important parts car will run low 11s easy have way more pictures
thanks for looking ray
