NationalGN
- May 20, 2009
$5400 o.b.o. clean title 78,122 miles 4th owner
Location_ NY/suffolk P.M. me here/call 631-681-1456
MECHANICAL_Stock internals,heads etc.Runs and drives BUT POSSIBLY needs bearings somewhere and
or oil pump clearance loose.50-60psi startup/_ @180f 10-15psi or lower if hotter temp.NEW Double roller chain,Front cover stock w/all new parts. Gn1 Extreme Intercooler, Aluminum Radiator, Turbo Tweek fuel pump,vacum break setup.
TRANSMISSION_ shifts good. NEEDS radiator fan,upper rad.hose,small exhaust leak sheared bolt/crossover pipe. MAF sensor works but needs replace (knock test/stumble).
INTERIOR_Good shape/replaced carpet,minor cracks,a/c and radio no work.Cusom tr/billet shift handle.Original buick owners manual,a/c delco radio manual also.Tilt wheel,Elec. seat/window work.
BODY_Needs repairs rust hole pass. side door, driver door good,cracked header,minor paint cracks,needs front/rear fillers.Floors are solid (sanded/painted 2x).Some surface rust undercarrage.
Thank You to all Moderators and community members/a website for Unique American Musclecar.
