1987 Turbo T , HOTROD Magazine
AintNo8
1987 Buick Regal T Type
Featured in HOTROD Magazine
(June 2000)
Body
Beautiful Neon Blue Paint
Fiberglass Paint to match Bumpers
All Steel Panels
Trunk
Gray Carpet
New Red Top Optima Battery Located in Spare Tire Well
Master On/Off Switch Located Under Car on Spare Tire Well
Engine
.030 Over 3.8 109 Block
Ported Factory Intake w/ Ported Hemco Plenum
70 mm Throttle Body
As Cast Champion Aluminum Heads
1.90/1.60 Valves
.495 Lift 224 Duration Cam
8.85" Hardened Push Rods
65 lb Fuel Injectors
Billet Steel Main Caps
PT54 Turbo/ 27PSI Boost
Precision .63 Exhaust Housing
Terry Houston 3” S.S. Down Pipe
TRW Forged Pistons 7.8:1 Compression
Stock Rods
Stock Crank
Stock Ignition
Charged Air Front Mount Intercooler
Aluminum IAC Relocator
Kenne Bell Ram Air Kit
Transmission
1987 GM 200-4R 4-SPD Automatic
Built by First Transmission, Auburn Hills,MI
Stageright Trans Brake
Precision 3,200 Stall, 9.5-inch Convertor
B&M Transcooler
Fuel System
Twin In Tank Walbros w/ HotWire Conversion
Stock Lines
Adjustable Fuel Pressure Regulator
Rear-End
Stock Driveshaft
Front Driveshaft Loop
GM 8.5 10 Bolt
Moser 30 Spline Axles
12 x 1.50 mm Long Wheel Studs
Eaton 30 Spline Posi Unit
3.42 8.5 Ring & Pinion
Moser Rearend Cover w/Girdle
Factory Aluminum Drums
Air Bags In Rear Coils
Southside Lower Control Arms
Stock Upper Control Arms
Exhaust
S.S. 3” Single Shot Exhaust w/ Dump
3” Dynomax Bullit Muffler
Factory Exhaust Manifolds
Wheels & Tires
Convo Pros
15x4 Front
15x8.5 Rear
Front Tires: Mickey Thompson Sportsman 28x7.5
Rear Tires: ET Drags 28x10.5 w/Tubes and Screwed
Air/Fuel Management
Big Stuff 3 w/Wideband 02 Gen 1 SEFI
Interior
New Headliner
New Sunvisors
New Autometer Electric Cobalt 30lb Boost Gauge on Pillar
New Autometer Electric Cobalt Fuel Pressure Gauge on Piller
New Dual Gauge Pillar
6-Point S/W Roll Bar W/Singout Bars
Highspeed Fan Override Switch
Hurst Roll Control
Pics can be viewed at: www.hotrod.com/featuredvehicles/80658/
Pics dated Sept, 2004 www.tamrazs.com/turbobuick/
Asking $21,500 O.B.O. or Trade
I will be providing current pics weather permitting.
Thanks.
vader87
Protected Freedom for 27 years! Thank a Veteran!
I talked to you a couple of months about buying the but my money situation did not work out :frown: . This has got to be my favorite TR EVER! Just to let you know my brother is in the market so I am sending him this page. I really hope there will be a deal struck!
MeanBuicks
Scaring the neighbors!
Where's that valve cover bolt? :confused:
Killer T BTW! :cool:
AintNo8
Thanks, Speed
The 1987 GN you see at the bottom that link is for sale also.
Pics of the GN are dated November, 2005.
Look for the thread started by DETROITBADBOY in the "Cars for sale" section.
who gave you a dollar????
i think that pm would mean a road trip!!!!!!which means scooters saloon :cool: and my buddy paul see ya soon Scott detroitbadboy ialso appreciate all the kind gestures and comments on the black t-type but I need to sell the grand national have fun happy motoring and as always drive unsafely
rubes
AintNo8 said:
Any interesting trades would be considered.
How 'bout a '70 GTO Judge :wink:
AintNo8
Sorry to all...
A fellow member brought this to my attention.
I put down the wrong year of publication of the issue.
The issue of HOTROD was June,2002
