1987 Toyota P/U "Hilux" 9 sec 2jz Hybrid
87chrisss
BLUBYU
1987 Toyota Pickup Shortbed with 2JZ-GTE and TH400 fully built
-Tuned and currently running E85 Ethanol
-Precision 76MM
-Brian Crower camshafts 264/264
-Tial waste gate
-Tial blow off valve
-An extra Dummy BOV where the nitrous is fed.
-Custom 3 row aluminum radiator
-4" inter-cooler with 3" aluminum piping
-Custom one off stainless downpipe And exhaust all Stainless / and Vband easy removal.
-Custom Fuel Cell 10 Gallon with all braided lines
-Magnafuel Pump Custom mounted bracket
-Custom Hideaway Nitrous box hidden
-All AutoMeter gauges on a custom dash and AEM wide band
-TH400 fully built with reverse manual valve body with electric trans-brake- Valve body is also studded has billet internals. ATF plate Custom Bellhousing to mount up to the Chevy 400
-Cheetah Turbo Action Shifter
-Line Lock
-Custom New Driveshaft
-Custom Driveshaft loop
-8" Toyota rear end with 3.73 gears
-PTC N/L with all the goodies. Best of the best.
-Weld Wheels Draglites on drag radials
-New Brakes
-All original body and interior -2200 cc injectors custom fuel system with magnafuel in line fuel pump
-100 shot of nitrous to eliminate turbo lag and will turn off at 15 lbs pounds of boost with a optional manual override for just in case.
EMS Stinger 4 standalone, will sell with laptop and tuning software -and much more to list, over $30,000 invested without the labor
CUSTOM EVERYTHING the list goes on.
Easy Low 9's and there is def 8's in her. No Cage Street monster.
786-487-9775
18k
Just a few pics text me if your interested.
The wheels in the picture are not the wheels that come with the car! Car comes with its stock wheels!
Car was evaluated at 23000$
GN looks nice Steve. I'm not really trying to put up any cash at the moment have easily over 20k in the truck if your in the states and your close to or want to take a trip to Miami feel free to swing by and take the truck for a spin whenever.
Well if you change your mind 5k plus your truck and we have a deal! I will even diliver the car!
That isn't the truck from back in the day that used to roll around South Florida on carbon fiber rims? The chances of 2 2JZ trucks down there... doubtful... and if that's the one, I've seen it on the streets and it was a pretty awesome ride!
Bump still available open to trades here's a few low 6 sec runs and one run against a turbo ls regal
I have thought about building the same project someday. I owned a '95 Lexus SC300 w/2GZGTE running a T78 turbo. At 17psi first through third gears were almost useless.
GLWS
