1987 Grand National Restored
The car has 102k on the body and has never been past 15 psi due to having the stock waste gate. Engine now is .030 over with TRW pistons and light weight pins, ARP rod bolts,heavy duty main caps with ARP studs,custom earson can with adjustable push rods,ported stock heads,cometic head gaskets,and modified oil pump. Dual fans,2 3/4 exhaust,and a new walbro fuel pump. As you can see this motor is ready to bolt on 700+ HP or just drive it as is. The body was stripped and painted including the jams. New carpet and headliner also. If your serious call me at 414 736 4873 $18500.00 obo.Also the antenna hole was welded up and I installed a windshield with the built in antenna.
Nevermind on location I see it says chicago. When you took it apart did it need rust repair? How are door seams etc?
No patches and the door seams are perfect.2012-11-18_11-01-02_2.jpg 2012-11-18_11-01-58_49.jpg 2012-11-18_11-01-31_372.jpg IMG_20120413_115845.jpg
car is beautiful, i am a newbie and dont understand what " ready to bolt up 700 hp" means? Also i am a month -2 away from ready to purchase will it still be available for sale from there ?
I am sure he won't mind securing the car for you until you can purchase it in 2 months :rolleyes:
