George Huh
Huhsler!
- Oct 15, 2013
AMAZING condition. Sounds and drives great, and guaranteed to turn heads everywhere you go. I've driven this car from DC to Key West and Boston and back. It is turnkey, ultra-reliable, and ready to run!
The car has high mileage on it, nearly 170K miles, but engine's only got 20K miles in 10 years. The transmission is even newer, rebuilt by Dynotech in 2007, has a very stiff shift and extremely strong lock-up. The exterior was repaired with hammered, spring steel metal work and a new paint job three years ago. The interior is extremely immaculate and very comfortable, with Dynamat and Acoustimat'ing in all quarter panels and doors. Add to that an Alpine stereo with XM and you get one of the best rides in comfort and speed.
Here is an incomplete list of detailed upgrades and improvements made to an already impressive car:
o New paint three years ago, needs a little buffing on certain areas to get it back to perfect, stained from leaves sitting on top.
o Newly built transmission by Dynotech Performance with:
o Reconditioned BR valve body
o New separator plate
o High flow lock up solenoid
o 3rd and 4th gear valve body switches
o Billet 2nd apply servo, modified
o Custom shift kit
Rebuilt engine by Jack Merkel with the following:
o XP plus fuel pump
o Voltage booster
o Hot wire kit
o Accufab Adjustable fuel regulator
o Fuel pressure fuel rail gage
o 160 degree thermostat
o 009 (42.5#) Lucas injectors, newly cleaned and flow tested (result sheet available)
o RJC Racing Boost Controller
o Adjustable pressure regulator for boost control
o Modified oil pan with magnetic drain plug
o Manley "severe duty" valves
o Moly piston rings
o Diamond forged turbo pistons
o Super duty alloy main bearings
o HD connecting rod and cam bearings
o Speed Pro double roller timing set
o Competition Cams "dyno proven" custom grind hydraulic camshaft
o ARP connecting rod bolts and main studs
o New core plugs
o Precision ground crankshaft
o Precision balanced rotating assembly
o Blueprinted oiling system
o Blueprinted timing cover
o Speed Pro high volume oil pump with thrust plate
o Oil passages enlarged and smoothed to enhance oil flow
o High performance hydraulic lifters
o Heads machined with 3 angle valve seats, exhaust bowl area enlarged with 4th angle
o New exhaust valves undercut to enhance airflow
o Viton seals
o HD LT1 spec valve springs
o Heads glass beaded
o Heads milled for metal O-ring around each cylinder
o Heavy duty water pump
o 12 inch 2800-3000 stall torque converter
Engine/Electronics/Interior Improvements:
- MAF Translator GENII
- Extender extreme G chip
- LS1 MAF
- Innovate LC-1 wideband O2
- Powerlogger data logging instrument
- Alpine CDA-9886 head unit
- Alpine 10 inch subwoofer, SWE 1243
- Alpine subwoofer amplifier, MRP-M1000/M500
- Alpine stereo amplifier
- Alpine PXA-H100 Imprint audio processor
- Alpine KTX-H100 Audyssey Imprint sound manager
- Audiovox CNP2000UC XM interface adapter
- FIPO Stereo Bluetooth Adapter (for music streaming from your smartphone)
- Code Alarm SRT 1600 1 mile remote alarm system and keyless entry
- Factory alarm system
- Front end brace kit
- Rear seat brace kit
- RJC airflow distribution power plate
- Caspers knock gage
- Oil pressure gage
- Boost gage
- New fuel injector wiring harness
- Upgraded battery power cables
- Upgraded grounding system
- Cam sensor upgrade kit
- Nitto 275-50-R15 radial slicks on rear
- Rebuilt front end suspension
- Black high-grade car cover
- Passed VA state emissions every year
- Original owners manual
- Original maintenance schedule manual
- Original warranty and owner assistance manual
- Hooker Performance 2.5" cat-back exhaust
- 3" downpipe
- Mobil1 synthetic oil
- All car seats replaced, from low mileage car, looks brand new, no holes, no stains, excellent condition
- New headliner
- Power brake booster, vacuum assist, replaced original powermaster
Only real thing wrong is the horn harness needs to be replaced to get an operational horn.
Need to sell due to fed budget cuts and new child on the way. Trading one baby for another! lol.
Someone please give her a good home...
o Custom shift kit
o XP plus fuel pump
o Voltage booster
o Hot wire kit
o Moly piston rings
o New core plugs
o Viton seals
- LS1 MAF
- Oil pressure gage
- Boost gage
- 3" downpipe
- New headliner
