Stroker-ace
Boosted-brick
- Oct 6, 2008
Location: Stafford Virginia, Va beach, anything in between
Means of contact: PM's
Price: ASKING $25,000, NO trades. NO joyrides, cash in hand first.
Description: Up for sale is my beloved Grand national, The car has a long history, Countless hours of build time and I'm not typing it all out because it would take forever. So I'll Just list the mod list and some pics for now. I'll have update pics of the interior and engine bay when I get home from work today I promise.
Engine:
Tuned by Ed Hutchins (fomerly of VA speed)
5.3 LM7 from a 2003 Silverado
LH8 Oil pan and windage tray from an H3 hummer (tapped for oil return)
317 heads
Cometic head gaskets
LS6 ZO6 valve springs
Comp cams Hardened Pushrods
LS6 ZO6 Cam
LS6 ZO6 Oil Pump
ARP head and rod bolts
LS6 Intake
Ported stock throttle body
160* Thermostat
hard radiator lines
Third gen camaro radiator
Truck alternator
Billet tensionor (keeps it from throwing belts)
No AC but has power steering.
Flow matched 60# siemens injectors
Truck coil packs
Ford racing custom length wires (LOLOLOLOLOL)
SNOW water/Meth injection kit
Walbro 255 In tank pump
Custom solid motor mounts
PSI conversions stand alone wiring harness
Stock ECu from 2001 WS6 firebird
Turbo Setup:
Master power T76
Custom hot side Modified EXTENSIVELY by Shawn ramey and RAMEYBUILT.
Custom 3" RAMEYBUILT turbo-back single **** exhaust with 1 Borla muffler
3" electric exhaust cutout
Tial 38mm wastegate with 15# spring
Massive Intercooler
3" Aluminum charge piping
STainless steel braided nitrous line for oil supply
Transmission/rear axle:
T-56 with around 40K on it
TICK adjustable master cylinder
LS7 FLywheel
LS7 clutch and pressure plate
Hurst short throw shifter
Custom tranny crossmember
Energy suspension transmission mount
Stock rear end housing
Detroit locker
3:73 rear gear set
moser hardened axels
C-clip eliminators
Wheels/ Tires
XXR 521 series 18" staggered
Front: dunlop runflat
Rear: eagle F1
Suspension/brakes
Spohn front and rear sway bars
Spohn Boxed solid upper rear control arms
Spohn Boxed solid lower rear control arms
Eibach lowering springs
Air shocks in rear
Bilstien shocks up front
Blazer brake conversion (2001 2wd chevy blazer spindles, 2 piston front calipers, new wheel bearings and lines)
Drilled and slotted front rotors
Aluminum rear brake drums.
Brass proportioning valve. (new)
Vacuum brake booster conversion (new)
Interior
Autometer cobalt guages: Speedo, tach, fuel level, water temp, oil pressure, volts
AEM wideband gauge
Hurst pistol grip shifter
Door panels stripped of pulls and recovered in grey suede
Sony Cd player with aux input
Polk audio speakers.
The body of the car is rock solid, no rot anywhere. car was repainted about a year and a half ago, paint needs some work but I can arrange that with the buyer. has new weatherstripping all around, and also has fiberglass bumper fillers. Now on to the few cons of the car:
-Power windows are pretty much done.. they go up and down but not without some help. just needs some new window motors.
-Front seats have a few tears in them
-No A/C
-Needs an alignment
-Paint has some bad spots that need to be fixed
This car has taken me two years to build, and has had alot of people help, its been my pride and joy and my baby I hate to see it go. I have reached a point in my life where I want to start a fmily and there is no room for a project car in my life right now. Any other questions feel free to ask, but please dont PM me asking to explain my entire build.
Pictures:
Engine pics to come as soon as i get off work today.
Engine:
317 heads
LS6 ZO6 Cam
LS6 ZO6 Oil Pump
LS6 Intake
160* Thermostat
hard radiator lines
Truck alternator
Truck coil packs
Turbo Setup:
Master power T76
Massive Intercooler
LS7 FLywheel
Detroit locker
3:73 rear gear set
C-clip eliminators
Wheels/ Tires
Rear: eagle F1
Suspension/brakes
Air shocks in rear
Interior
AEM wideband gauge
-No A/C
-Needs an alignment
Pictures:
