1987 G/N Backhalf rolling chasis
maverick
I just took some pics today of the car I have for sale. Transmission and convertor is included.
10 pnt. roll cage
Ford narrowed 9" rear end w/spool
4.00 gears
Rear disc brakes
3.5" aluminum drive shaft
F.A.S.T system all wired and installed
Battery mounted in trunk
15 Gal fuel cell w/sending unit
Weldon fuel pump -10 feed line
4 link coil over Hotchkiss rear suspension fully adjustable
A/C components and blower motor removed
Trans cooler w/fan
3.5" DP w/full custom fabricated 3" exhaust w/race mufflers
Original dash w/tach, oil press., and temp gauges
PTE front mount innercooler w/aluminum piping
400 buick trans w/brake reverse valve body manual shift 3 spd.
G.E.R 8" 4000 stahl convertor
Remote oil filter mounted
T-top car from factory w/ pwr driver seat, pwr windows, pwr locks, pwr trunk release.
Fiberglass hood, all other body panels original
Interior is in great shape, no rips in seats
New carpet installed and cut at rear wheel wells
Car has never been wrecked, always stored inside, original paint (aside from hood) body has a couple minor 'dings' size of a thumb print. In the last 10 years this car has seen maybe 40 miles on the road. Doors are solid, no rust, and the doors DON'T drop when opened, and they close crisp and tight.
The car is set up to run 8's just needs an engine to take it there.
I believe the odometer is approx. 91k miles.
Hope the pics will show up ok as to the lighting was a bit poor inside the shop
Asking price is $15k or best offer
more pics....and more coming.
Here is a pic of the stage II block that well......FAILED! This is what happens when you have someone build an engine you don't know the history of, after $12K and about 10 street miles!!
Where about in michigan are you located? I'm comming to battle creek this weekend and might want to come take a look at the car. If its not to far away. Thanks
The car is inside Bruce's shop in Roseville, Michigan. If you click on his business link on the home page here (Aggressive Performance) you can get the address and mapquest it to see if you want to go look at it and I will meet up with you. A guy by the name of Fred Lydecker did all the backhalf and rollcage work, it is supreme workmanship with nothing done the 'cheap' way.
yeah i saw this car a few weeks ago there it was pretty nice. I remeber seeing that block it looked worse in person good luck on the sale
Getting out of G/N for awhile
Deciding to put her up for sale again. Odometer reads exactly 81728. Doors open and close like new, no dropping. Asking $12000. O.B.O Title is clear and ready for your name to go on it :p
The car is at my house in Lapeer Michigan. I also have a set of stage II heads w/valve covers, race gate, set of steel main caps, and a large turbo 4 bolt dual scroll bout same size as a 76. Make offer.
I am a motivated seller, haven't drove the car since 2004 which then only put about 10-15 miles on it. Good buy for street or race. All it needs is an engine put in it. Over $8000. was put into the cage, rear end, suspension, and backhalf work alone.
I bought a stageII short block from Bruce's shop last summer, that I think use to be yours? This has nothing to do with you now. However, I have a few questions about it, that you might be able to clear up for me. If it was your short block, could you please let me know. Thanx!
I have no idea if it was mine or not lol, I believe mine was sold to a teacher of a sort or something. If you are the one pm me your phone number and I'll call you and answer your questions.
