1987 Buick Turbo-T
TKMBUICK
1987 Buick Turbo-T / Chrome Package / White with Blue Interior with Bucket Seats & Console / Concert Sound II with Power Antenna / Air Condition / Tilt Steering Wheel / Electric Trunk Release / Delay Wipers / Autometer Ultra-Lite Oil Pressure Gauge / Autometer Ultra-Lite Water Temperature Gauge / Autometer Ultra-Lite Boost/Vac Gauge / Autometer Ultra-Lite Volt Gauge / Knock Gauge / Console Gauge Pod / A-Piller Triple Gauge Pod / Scanmaster 2 / Shifter Detent Plate / Simulated Aluminum Speedometer Pandel Kit 145MPH / Turbo-T Black Glovebox Plate / "T"- Black Pullstrap Screw Covers / Houston 3" Down Pipe with Cutout / Houston 2 3/4" Cat Back with Dynoflow Ultra Flows / March Underdrive Pulley Set / Tinman Cold Air Kit / Upgraded Alternator Pulley Fan / Black Powered Coated Mass Airflow Pipe / Black Powered Coated Inlet Pipe / Passenger's Side Breather By-Pass Kit / Custom Made Oil Fill Tube Breather / Drivers Side Relay Cover / RJC Airflow Distribution Power Plate / EGR Block Off Plate / ARP Head Bolts / Brass PVC Shut-off Check Value / 5 Angle Value Job / Manley Stainless Valves Both Intake & Exhaust / SBI Push Rods / Teflon Coated Cam Bearings / Comp Cam# 69-248-4 / TPS-TEC Throttle Enhancer / Torque Strap / Fuel Pressure Test Gauge / Quad Air Fuel Pump / Fuel Pump Hot Wire Kit / ATR Fuel Pressure Regulator / 42.5LB Injectors / Cotton's High Voltage Coil Packs / Air Volt Booster / 160 Degree Thermostat / Duttweiler Big Neck on Stock Intercooler / Custom Build Trans by Countywide Trans / 2000 Stall Lockup Tonventer / Deep Aluminum Trans Pan / Shift Kit / ARP Torque Converter Bolts / Front Frame Braces / Connecting Front Brace Kit / Under-The-Hood Brace Kit / Rear Seat Frame Brace Kit / B&M Line Lock / 3:42 with Auburn Pro Posi Unit / Custom Rear Pinion Snubber / Tubular Upper Control Arms / Billet Aluminum Lower Control Arms / Ebelbrock Tubular Frame Braces / S-10 Rear Wheel Cylinders / Soft Compound Rear Brake Shoes / 1 1/2" Front Sway Bar / 1 3/8" Rear Sway Bar / KYB Gas-A-Just Shocks / Driveshaft Loop / Airlift Drag Bags / Trick Flow Rear End Cover / GN Rear Spolier / Aluminum Front & Rear Bumper Supports / Quick Grille Emblem / GTA Wheel Caps with "T" / Quick Release License Plate Bracket
128,000 Miles
Needs Paint & Front Bumper Filters
Vin# 1G4GJ1170HP426086
AR9 C60 E5Z GU6 NA5 N89 UM6 U75 V73 11Q 27I 7YW
A01 D35 FE3 G87 LC2 NP5 PON UQ1 VD6 YT9 11U 279 8PZ
BS1 D55 FFL J42 MW9 NQ5 QYZ UW4 VD7 Y56 27B 6YX 9PZ
B94 D7I GMD J50 MX0 N33 T47 U23 VK3
U.WA3967
NO TEXTING PLEASE CALL OR EMAIL ME
Check ebay #280650454668 for pictures
Call Tim at 267-243-4792
tkm55@verizon.net
i noticed on one of your previous post's that you had no oil pressure in the egine did that ever get diagnosed/fixed?
I took it to Steve Kaminski Turbo High Performance in South Jersey it was a broken rocker shaft two bent push rods all fixed and running great
