ForensicDoc
I see dead people!
- Apr 9, 2006
Asking $12,000. The car is located in San Antonio, TX. This car has the factory T-tops and Aluminum Bumper support options, which are very rare on the T-Type Limited. The T-tops are in excellent shape and I have the original storage bags. The car has no fluid leaks whatsoever. The previous owner had a new rear main seal and new valve springs installed, and the transmission has been rebuilt. The odometer reads 105,623 miles, which to the best of my knowledge is accurate.
The car has power steering, power brakes, power door locks, power driver's seat, air conditioning, cruise control, working lighted passenger dash panel (only seen on Limited), aluminum rear brake drums and power antenna (not working). I have a new power antenna that will go with the car. I have aftermarket Turbo 6 floor mats in the car, but have the originals which will go with the car.
I put a new stereo system in the car with a Sony CD deck, Pioneer speakers, and Sony 1000W X-plod amp hooked to two MA Audio subs in a sub box in the trunk. No cutting or modifications were done to install the stereo and I have all the factory pieces which will go with the car. I also had a Crimestopper pager system alarm installed. Stereo and alarm installations were professionally done.
The body is in good shape and the paint is an older repaint of the original color. The rear bumper filler pads are falling apart and the front bumper filler pads are cracked.
The car has the following additions/performance modifications:
• Custom chassis braces
• Custom rear seat braces
• Full urethane body bushings
• TA49 Turbo
• Chrome Turbo cover
• 50# Holly fuel injectors
• 340 Walpro fuel pump with hotwire kit
• 3" Chrome up pipe and turbo inlet pipe
• 3" down pipe to high flow catalytic converter
• Duttweiler neck intercooler
• 10 mm ignition wires with newer plugs
• TPS throttle enhancer
• Heated oxygen sensor
• Adjustable fuel pressure regulator and gauge
• Pillar mounted boost gauge
• Scanmaster II
• Custom vacuum block
• Newer Powermaster ball
• Newer shocks
• New variable rate rear springs
I have numerous photos I can email to anyone interested.
• TA49 Turbo
• Scanmaster II
• Newer shocks
