1986 wh1 car
turbot990
A member since 05
Im putting feelers out for my wh1 car , Im very busy and I will post more info real soon and pictures.Asking price is 15.500.00.765-744-6115 Kevin.1 Of 463 built in 1986 100 % street car fresh 109 30 over forged pistons stock rods and a std. std.stock crankshaft. with 2 center steel mains ARP studs 208 208 hyd cam double roller timing chain stock ported cyclinder heads stainless valves 110 comp springs 70 mm throttle body and plenium ported stock intake manifold 72 pound injectors adjustable fuel pressure regulator 67 bb.precision turbo postons headers 3.5 gn 1 down pipe gn 1 3 inch exhaust system precision front mount polished intercooler tubes with a blow off valve a fresh 2004 r stage 2 ptc 2800 stall eaton poss unit 3.42 richmond gears 30 spline mosier axles billet rearend cover HR.upper adjustable control arms aluminum lower control arms Hr parts rear sway bar Qa1 13 way adjustable shocks race frt.shocks alky kit reds double pumper and hotwire wire kit 275/60/15 nito,s centerline telestars 6 point rollbar
Ac is ice cold great heater nice cd player Eric marshalls SD chip scanmaster 2.1 the car is tuned on pump gas and alky Eric,s power logger B/M Quick Silver. shifter, Fuel pressure switch This car is 100% tunable and very simple to tune,It need nothing at all.There is Know rust anywhere.Relocated battery Kit. Wide Band O2.
Very nice and reasonably priced. GLWS
Kevin,
You mean that fellow didn't pull the trigger and buy it?
He musta got cold feet. (or cold wallet)
We spoke on the phone and I told him, pound for pound, I'd buy it in a heartbeat.
Kevin,
Me??? You got the wrong guy buddy..
Ok I understand that but did it ever get dyno'd or are u guestimating that it'll go in the 10's ?
With the combo i see know reason why it shouldnt run 10s i had the same combo and ran some 10.60 :)
