1986 T-Type Rolling Chassis $ 4,950.00 plus shipping
White w/ Burgundy interior
Original Turbo Car
Solid Roof
Clear Title
6 Point Roll Bar
Frame Notched in rear
Frame Reinforced at lower bar mounts
Trunk Braces
Manual Steering Box
Front Comp Eng Adjust Drag Shocks
Rear Comp Eng Adjust Drag Shocks
Transmission crossmember for turbo 400
Drive Shaft for Turbo 400 & 9"
Drive Shaft Loop
Moser 9"
3.70 gear
Spool
35 Spline Axles - 1/2" Studs
Wheelie Bars - LOOSE
Metco Adjustable Bars Upper
Metco Lift Bars Lower
Driver Air Bags w/ Spacers
Pass Air Bags w/ Spacers
Axle Snubber
Weld Drag Lite Wheels
3-1/2 x 15
10 x 15 w/ screws
M/T ET Front - 26 x 3.5
M/T ET Drag Rear - 28 x 10.5W
Vacuum Brakes
Line Lock
Adj Proportioning Valve
Kirkey Drivers seat
6pt Cam Lock Seat Belt
Lap Top Stand
B & M Hammer Shifter
Factory console
Pass & Back Seats Removed
Aluminum Divider in Trunk.
Auto Guage Tach w/ Shift Lite
Auto Meter EGT
Auto Meter Boost
Auto Guage Water Temp
Auto Guage Oil Pressure
ANS Knock Detector
Fiberglass Hood
Fiberglass Doors
Fiberglass Trunk - LOOSE
Fiberglass Front Bumper
Fiberglass Rear Clip
Lexan in Doors
10ga Fuel Cell
SX pump
-8 Braided fuel line
CAS Radiator
Electric Fan
Turbo Saver Remote Filter System
Engine Wiring Harness
Battery mount in truck
Disconnect Switch
Welding cable for ground
Welding cable for positive
Ford Starter Solenoid
Almost all parts removed from this car are in
plastic bins - Stock Interior, Windshield wipers,
Lights, etc. (except A/C, P/S & Doors)
Stock replacement doors could be reinstalled.
Factory hinge mouting area still intact.
Roll bar designed for stock door panels.
1.36 60' Times @ 7 psi launch
Race Weight: 2885 lbs
Aluminum Headed Turbo 6 with Liquid IC and Steel
Trunk
Car needs:
*Fiberglass trunk & wheelie bars installed.
*Front bumper fillers.
*Body work & Paint.
$4,950.00 plus shipping
Will Wheeler
Email: Wheeler4551@Yahoo.com
Original Turbo Car
Solid Roof
Clear Title
6 Point Roll Bar
Trunk Braces
Manual Steering Box
Drive Shaft Loop
Moser 9"
3.70 gear
Spool
Axle Snubber
3-1/2 x 15
10 x 15 w/ screws
Vacuum Brakes
Line Lock
Kirkey Drivers seat
Lap Top Stand
Factory console
Auto Meter EGT
Auto Meter Boost
ANS Knock Detector
Fiberglass Hood
Fiberglass Doors
Lexan in Doors
10ga Fuel Cell
SX pump
CAS Radiator
Electric Fan
Disconnect Switch
Trunk
Car needs:
*Body work & Paint.
Will Wheeler
