buickgngirl
10-sec-club
1986 Buick Grand National
27,782 original miles
Car does not have the original V6 engine – we bought it as a roller without an engine and chose to build a V8 to fit within our budget and for prototyping purposes.
This car is professionally built and gone thru from top to bottom. It starts, runs, drives and races flawlessly. MANY hours were spent dialing in the program and finessing her street manners.
ENGINE DYNO HP: 890HP, 14.2 PSI
CHASSIS DYNO HP: 718HP, 14.5 PSI
9.20’s at 148mph in the ¼ mile. Car is capable of running 8’s.
Race weight is approximately 3400 lbs. Body is all original sheet metal with a Fiberglass bolt-on VFN hood. Custom ground effects on the front fascia and rear bumper.
ENGINE DETAILS
BLUEPRINTED AND DOCUEMENTED. ALL DOCS WILL GO WITH THE CAR.
BLOCK: 1974 355 cid SPLAYED CAP BLOCK, 3970010 CASTING, ½ BLOCK FILLED, BILLET SPLAYED CAPS, SONIC CHECKED AT .220 WALL.
CRANK: EAGLE 4340 STEEL
RODS: EAGLE H BEAM
PISTONS: DIAMOND CUSTOM CONICAL DISH TURBO PISTON WITH 165 WALL H13 PINS
CAM: isky flat tappet CUSTOM GRIND TURBO CAM with thru-oil to cam face lifters
RINGS: tnt top, gapless 2nd ring
TIMING CHAIN: Cloyes Tru-roller
MAIN FASTENER: ARP 7/16” center studs, ARP 3/8” splayed bolts
HEAD FASTENERS: ARP 7/16” Bolts, 180psi
DISTRIBUTOR GEAR: GM melonized iron
CYLINDER HEADS: Pro Top Line (ProAction) ported 215CC with 2.05/1.625 valves
HEAD GASKETS: Cometic
PUSH RODS: Smith Brothers, 116 wall
ROCKER ARMS: Comp Pro Magnum stainless, 1.6 intake, 1.5 exhaust with stud girdle
VALVES: Manley inconel 1.625 exhaust valves, 2.05 SS intake valves
ANCILLARY HEAD PARTS: Titanium retainers, Isky tool room springs
INTAKE AND DFI: custom CNC ported DRYFLOW SDCE/AFI (airfuelinnovations.com)intake with 90mm throttle body, 83 # injectors, dual sync distributor, set up for traction control. Accel G7 DFI with wideband, professionally installed, programmed and tuned on engine dyno and then dialed in on chassis dyno and on the street and track. Car runs and drives flawlessly. Data recorder included.
ICE Ignition and coil
Oil pan: 7qt oil pan
Turbo kit: SDCE/AFI Twin Turbo kit (airfuelinnovations.com)
64mm Q-trims
Tial 44mm gates
Front mount intercooler with fan
boost is electronically controlled thru G7
down tubes are dual 3"
Car is also equipped with AFI/SDCE port injected meth kit.
Exhaust: true dual 3" exhaust, Dynomax mufflers, full tailpipes that exit in stock location over the rear end
Driveshaft: Denny's 3" steel with 1350 u-joints
rear end: Moser 9" 35 spline spool, 35 spline race axles, 1350 billet yoke, daytona pinion support, 3.73 gears.
tranny: TH400 pro tranny built by Dynamic in a 4x4 case with a transbrake, Kevlar blow shield, and a California performance Transmission converter. Full manual, reverse pattern. Also has huge 20x24 tranny cooler., tci flywheel.
suspension: reinforced control arms and boxes tied to cage.
rear sway bar is adjustable drop-link.
front sway bar is adjustable.
90/10 drag shocks front and rear
moroso drag springs front and rear
body and control arms are still rubber mounted for a nice smooth ride on the street and track.
Brakes are hydro power
cage: NHRA/IHRA certified rollcage, 12 point, 1 5/8" mild steel certified to 8.50 with rear supports to 4 link. Welded in front of dash for extra foot room. Also has knee bar under dash for 150+ MPH certification.
Street rims and tires – 275 x 60/15 MT drag radials
Race rims and tires – MT’s 28 x 10.5/5 on drag lite rims
Interior is all stock and in excellent condition. Carpet is brand new aftermarket. 5 point SFI seat belts driver and passenger seats. Headliner is original and in excellent shape. Window net is SFI certified for 8.50’s. Dash is original. Aftermarket Autometer gauges and assorted switches have been added to center console area.
See here for more pictures and information: https://www.facebook.com/#!/media/set/?set=a.10152139767910729.1073741902.202655640728&type=3
Asking $38k or best reasonable offer. Car is turn key ready. Please call 401.270.8409 or email sdconcepts@yahoo.com
ENGINE DETAILS
RODS: EAGLE H BEAM
64mm Q-trims
Tial 44mm gates
