1986 Buick t type
For sale
1986 Buick T Type
Engine rebuilt about 10,000 miles ago, car has 116,000 miles, Runs and drives great, Body very solid, Paint is good for a driver not show car quality, there are many imperfections in the paint. I believe this car is a designers series car,There is no truck sticker to back it up but the cowl tag shows the paint code is 15 and 19.Interior is nice but needs a carpet due to stains that won’t come out. Car has run a best of 11.67 in the ¼ at 111 mph
Engine specs
Trw Pistons, 212/212 comp cam, Rjc Head gaskets, New front timing cover, double roller timing chain, Homeported heads, Under drive crank pulley, Homemade cold air intake, Stock intercooler, 3” poston or kirban 2 piece downpipe with ported elbow , Pypes Stainless exhaust with a cut out added, Gt6157 turbo, Older SMC meth injection, Manual Boost controller, Turbo Tweek 5.6 alky chip, New engine mounts, Supra TT fuel pump hotwired,Adjustable fuel pressure regulator, Msd 50# injectors, Newer coil pack, Msd spark plug wires, new water pump, New T Stat housing with a 160 Thermostat, Comp 980 valve springs,
Transmission
200r4 BO code, PTC 3,200 lockup torque converter, Super servo, New TV cable, B&M trans cooler
Body
F Body Radiator, Intrepid dual fans, CS144 impala Alternator, Weld drag lite wheels,Front tires are like new rears will need replacement soon, Down to the wear bars, Drag shocks on front and rear, Air bags in the rear springs, 3.42 posi rear, Extra vision low beam headlight bulbs, Sway bars on front and rear, Aluminum Rear drums, Scanmaster, Boost ,water, oil pressure gauges, Line lock, New sway bar end links and bushings,87 grille and 87 turbo t emblems
Options
Concert sound, Rear Defog, Power windows, Power Locks, Power antenna(that works), A/C (that blows cold), Manual adust mirrors(from inside the car)pass side doesn’t work, G80 Posi,
factory security system
Stock parts included
Stock downpipe, injectors, chip, Cat converter, egr valve,
Things the car could use to have done
Weather strips are in poor shape, New rear tires, Needs the plastic trim that go’s on the passenger seat, Carpet,
I am asking $10,000
My email is mikes440dodge@hotmail.com
Phone is (716) 831-8941
Located in Amherst, New York
I've seen this car and it is nicer than described. I don't think the paint is as bad as stated. Not a show car but no rust & the paint? A nice 10 footer. Car runs great considering it's running through the stock inner-cooler.
And the seller is an awesome guy, & straight shooter, ready to help anyone who needs it. If someone is interested, I can inspect it for you & take more pics of any areas that you are concerned with.
IMO, well worth the $9,000 K that he is asking.
Thanks ken.
Im really shocked no responces on here.I have it listed all over so im sure i will sell it soon.Seeing i have about 14k into it i figured 9 k was pretty cheap.
