1985 Grand National Motor pulled rebuild started. Block and crank baked and maged. Crank polished, Block rr and honed new cam bearings and freeze plugs. Standard bearings, rings. All parts to assembly except cam and lifters. Heads still need looked at.Turbo good. Transmission still in car works good except shifts 1st,3rd, OD. Doesn't slip. Very solid body and nice doors. Body stripped to metal and primed. Front floor rusted. Rust cut out and patched. Small rust spot on left rear quarter. alittle bondo around trunk lock and right quarter [dent].Windshield cracked. New front bumper fillers, window weatherstripping, upper control arm bushings, front brakes and rotors. Interior is in pretty good condition. One rip in passenger seat. Dash cracked on top, tilt sloppy. Needs shifter handle replaced. Has full stainlees exhaust, mufflers need replaced. Has 3.42 non-posi rear. Engine bay cleaned and painted. I labeled harness and parts so assembly shouldn't be too bad. I'll try to get some pics on here or e-mail me at jefferyh007@aol.com $2000 or might trade.
