1977 Buick Superhawk (skyhawk)
cruzn57
Still plays with cars!
$18,000
GN engine and trans,
eng has forged pistons, 206 cam, some head work, HD springs,
6152 turbo, HD boost actuator, 60 lb inj, turbo tweek chip, (2 mos old)
BRF trans, coan 2600 conv, remote trans cooler with Tstat fan.
chassis work done by "Modern Muscle Car works"
tubular frame connectors, cross members, "K" frame (eng cradle)
custom torque arm mount/ crossmember.
"overkill" upper and lower tubular A arms,
S10 spindles and brakes, Flaming River rack and pinion ,
custom ADJ panhard bar ,
auburn Posi, Richmond gears,(3.08) Superior axles.
walbro 340 in tank pump,3 bar map sensor,
Griffin alum HD radiator,GN modified intercooler.
custom intake /aircleaner, 3in down pipe,
full 3 in exhaust out the rear.
new Sanden , chrome a/c compressor,
Sacnmaster "G"
Julios Alky , with new pump.
Auto meter gauges (phantom)
Pioneer stereo, Rockford -fosgate amps (2)
MTX sub inclosure.
Showheels 17x7 front and 17x8 wheels,
nitto rear tires
LED head lights
front seats just redone, OEM style.
car is FUN ride, at 22psi, and 2800 lbs,
it does get down the road very well!
car need cleaning under side I live on dirt road.
$18000 firm,
in AZ
trans cooler lines , to rear mounted cooler . with T/stat fan
orig 7.5 ( I think) rear end,
auburn posi, Richmond gears, and superior HD axles,
with rear girdle.
How fast has the car gone? The 7.5 would scare me a little with the power that this car looks like it makes.
But if I had a extra 18k lying around.... well you know. :cool:
never ran it, wasn't to be a drag car, but a road car,
that's why the tire size, they spin,instead of breaking something'
I had a white Monza back in high school, had a ton of fun in that thing and it was only a weak 4 banger. I bet this baby is a blast!
A built 7.5 works fine on a light car like that as long as you don't bolt on slicks.
IF...…… someone is interested, shoot me an offer, worst I can do
is ridicule you in public, LOL
cash talks,,
car is just sitting,
to many other projects,
