Used-2 row, crossflow core aluminum radiator. This radiator was used in my GN in order to facilitate a forward facing turbo install. The Rad has -16 inlet and outlets plus a -8 on the lower side tank to run lines into a purge tank. It has no provision for filling. It was designed to be used in a vertical position or horizontal . Installed on the radiator is a 16in extreme Spal fan.
This radiator will not fit a stock core support without mods, but it saves lots of work when swaping to a V8 and big turbo. Included are various -16 fittings and hose to complete the job. My V8 GN ideled @ 180 with no Tstat.
There are several V8 swap TR's using this type and size of radiator. If you are thinking of a swap with a forward facing turbo, this will save lots of work.
425.00 for all plus shipping.
The photo below shows the typical install:
