What is the advantage of running the heavier wt oils? Most engine wear occurs on start-up especially with cars that sit for a while between drives. Factory specs are 10w30 -10w40 right? Just curious? .......
Just want to make you aware the this is a "turbo Buick" site where members come to share information on PERFORMANCE and how to best keep their ride reliable while tripling [and even more!] the power that the factory gave us!
Wear at start up is not a concern, as the increased RPM and HP is where our problems can and do show up, so factory recommendations are not really applicable here.
As far as the test fixture with a lever and bearing, it has been around even longer than I have for hucksters to sell their brand of snake oil. There are better modern methods to determine oil properties and quality.
Also, over the 25+ years since the turbo Buicks have been in the performance arena, we have found from real world experience what works well, and what does not.
I do not know any racers, Buicks or others, that trust light weight oils to protect their expensive race engines.
Like I stated earlier, there are MANY opinions on type and brand of oils to use, but in our narrow discussion of the overworked turbo V-6, we need to be sure we have the right stuff for the level of performance we are want.
Since the original poster listed his home as Las Vegas, the desert heat is much more extreme than most areas of the country, so my opinion is he is right on with his selection.
