12.14@110
85tr
New pb , stock hotair long block from intake to pan no porting on anything. Stock converter and transmission with a b&m shift kit . Ta33 turbo through an ebay front mounted intercooler , 3inch dp and 42lb injectors. Was between 27-29 psi with 92 and methanol ,locking the converter in 3rd.​
Nice, so was it a hot air car and you flipped the turbo and piped in an intercooler or did you only use the hot air engine bc you needed an engine?
Hot air car hotair setup with the turbo rotated. Old lee Thompson down pipe.
