Im guessing the '87 gasket, because they are thicker than the the '84s to go with the shorter deck height of the newer block. From what I hear the thickness of the'87 gaskets compressed is .060 and the '84's is .018. There is a thread over in the General Tech forum titled Head Gaskets (I think), might have some more info.
Im sure someone else that knows for sure will chime in, but I am willing to bet the '87 gaskets are the way to go to give you the correct compression ratio.
P.S. on my engine, the compression ratio went up slightly with .030 over bore, but went down by putting '87 gaskets on it.
