turbotony1
- Mar 3, 2011
Hi. I'm new to the site and LOVE the responses I've been getting from everyone so far! I'm rebuilding my stock 109 87 Turbo T (100,000mi.) The car was owned by an elderly couple since new. The motor probably never saw 4,000 RPM until I bought it 5,000 miles ago. I'm aiming for 600 + engine H.P. I will put plenty of street and strip miles on it.
The engine has never been rebuilt before. With the amount of power I plan on making, I have read a lot about reinforcing the bottom end. I don't know what route to go with it? I'm trying to be as easy on my wallet as possible.
Replace stock caps with billet steel caps?
Girdle with stock caps?
Girdle with two center billet caps?
Stronger crank with two center caps?
Stronger crank by itself?
Would internal balancing and a good fluid dampener have much effect?
I will be running a roller cam and roller rockers, ported heads, a 61-66 mm turbo, JE or Diamond pistons and have my rods re-conditioned. So I assume the motor will definitely see 6,000 RPM+ or -.
I know this is an opinionated subject, and there are lots of different theories. However, I'm just looking for the most cost effective way to get this engine up and running.
I'm just hoping to use some of the experience that many of you have on this web site. I'm hope someone can point me in the right direction.
Thanks in advance,
Anthony
Thanks in advance,
Anthony
