Hey guys I have a bad idle and my 02s are reading 0.87/0.56/0.32 and so on. I had just put in a new 02 sensor at the time because my old one was doing the same thing. My scanmaster readings are TPS .44 lv8 128 Blm 128 iac 32 MAF is 5 and fuel pressure is 43 line off. Even at cruise the highest they get is 685. I have replaced the MAF with the translator and brand new lt1 MAF. New coil pack and ignition module as well. I have a turbo tweak chip burned for my setup as well. Grounds are all attached to. What gives?
