grandnat86
- Apr 9, 2008
finally got my scanmaster and adjustable fpr installed, took the car out for a drive and the o2 mv were floating around 400-800 while cruising and almost 0 at wot, when i would recall it after it said 023 at 45 mph with no knock, car is running fine and not smoking or anything, fuel pressure is set to 43 with vac off, it also has a tt chip, the other numbers at idle are
af-4
l8-31
bat-13.5
int-128
bl-141
clt-196
tps-.46
iac-26
cc-51
af-4
l8-31
bat-13.5
int-128
bl-141
clt-196
tps-.46
iac-26
cc-51
