BoostedBug
Contents Under Pressure
- Oct 1, 2002
Originally posted by turbosam6
I just had to ask- what exactly did you smoke before you wrote that? Seriously, did that even make sense to you? I think everyone is more than happy to let you and your brother believe whatever you will, but since he has decided to respond to other threads saying that the plate may not work, its starting to irritate people. Did you read the 2 or 3 posts showing test results from pressure readings ABOVE AND BELOW THE PLATE?? I get the feeling you just want to stand firm in your ignorance, since you've carried on this far. And thats fine, but don't take others with you. Some people come to this board looking for useful information, they don't need to hear what 2 guys theorize to be true, when niether of them have any evidence to support their misbelievings. Argue all you want, but keep it in this thread, do not post elsewhere to some poor unsuspecting newcomer, that the power plate doesn't work, or may not work. Please?Thank you.
Damm you want some cheese with all that whine? Was these pressure test done static of flowing? Did they have some sort of restriction so it could build a boost type senario? "Like an Intake valve that is NOT friggin open all the time? If they did, what was the damm pressure on each runner with the plate and with out it?
I bet the pressure was the same on all cylinders without the plate.
gees...I did not buy the plate to run with my sheetmetal Intake..It was for the stock one......
