sounds like it's reading lamda. uncheck that option under the file menu.
i actually use the lamda scale to tune, just bc that is what i got used to try to run the e85.
i set everything under 110-130 kpa at target lamda 1.00 , then if it is running .93 a 7% increase in fuel SHOULD land it on 1.00.
This is the first time i did it this way really from close to scratch, having someone drive me around and holding it steady, my ve table was real close within an hour...
I'm just working on drivabillity, haven't really played in the WOT areas, yet. i know i can get 18 psi without knock so far.
