The idle is ECM controlled! If you are messing with the throttle plate screw, your TPS and IAC counts are most certainly out of whack! That screw will not raise your idle, it's your minimum air rate adjustment. The ecm will always lower your idle back down to 650-700rpm unless you have it so far out of spec that it can no longer do so.
Without a scan tool you are playing in the dark. If you can't afford a Scanmaster right away, pick up an OTC 2000 with a '87 gm chip. I got mine like brand new off ebay for $50.00 and change.
Like I said, if you've messed with the minimum air rate screw, you now know what the problem is without a doubt!
Good luck!
