GNONYX
- Oct 16, 2009
The reason why not to put anymore antifreeze into the since It will eat the bearings or corrode them, unless if the temp is really cold to freezing point that you have no choice, put minimal. Or just put water and place the car inside the garage.
Thanks to KingMoneyBank for coming to your assistant, and is it possible that you have a compression tester so both of you guys can do a compression test on each cylinder; to test if the HG is blown or not.
I'm not familiar with hot air system as the other guys are, but trying to give some ideas of the possibility like other motors
