zo6 Mass Air Sensor
No Problem
AC-Delco Part Number 213-3134, $49.32 and in stock NOW.
This is the 2005-2007 style Z06 MAF, which is used on many other GM vehicles as well.
i use to run that sensor it worked good but make sure that the translator is one of the newer models or you would have to buy the upgraded chip that fullthrottle sells, also you will need the special connector that they sell in order to make the sensor fit top it of with a 4" maf pipe and youll be ready to rock:cool:
Why is the 4" MAF so cheap ?? The 3.5 is like $90.00 from full throttle...
It's just the card. No tube or housing. You have to cut the slot into your MAF tube. Technically it has any dimension you want. It could be 4" or 4 feet. I think I have a pic I can post later.
Technically the tube is just as important as the sensor element, we went through multiple versions and lots of flow testing before we got it where we wanted it. Moving the sensor an inch forward or back can change the AF ratio 1 full point. The translator softeare is tuned to the pipe we sell.
Mike
